GreedyBumps
I have newly built and running with Windows x64. Problem is I cannot get SLI to work at all. Both video cards work very nice by themselves. I have checked bios version of both and it is the same.
The problem:
When I boot with both cards and jumpers set to SLI (and of course with the bridge) I get post and black screen with loading Windows x64 but after that the screen stays black.
The problem is the same no matter what drivers I use. I finally settled on 76.80 after extensively searching the net. I plug in the display (DVI, Dell 2005) into the upper card into the left plug (if you are looking at the back of the case).
At this point I am at a loss. I thought that if SLI did not work Windows would still load and that SLI just will not be recongnized. What am I missing?
I am thinking next step to flash bios from one card to the other using nvflash but it appears that this fix typically addresses the problem of second card not being recognized in Windows - so not necesserily my problem.
What surprises me the most is that this build is pretty much directly of the anandtech guide so I was hoping that things would work much nicer together.
System Specs:
DFI LANPARTY UT nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail
AMD Athlon 64 4000+ San Diego Integrated into Chip FSB Socket 939 Processor Model ADA4000BNBOX - Retail
eVGA 256-P2-N376-AX Geforce 6800GT 256MB GDDR3 PCI-Express x16 Video Card - Retail x 2 (but trying to boot with just 1 at a time)
Maxtor DiamondMax 10 6B250R0 250GB 7200 RPM IDE Ultra ATA133 Hard Drive - OEM
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZ4001024ELDCPER2-K - Retail
ENERMAX EG565AX-VEFMA2.0-SLI ATX12V 535W Power Supply - Retail
The problem:
System Specs:
