DFI LAN PARTY SLI-DR NF4 WITH OCZ "VX"PC400 , HOW TO?
mUcHiLuS
There's fans, i had a dfi lan party sli -dr with 1gb 512x2 pc4000 VX "Voltage Extreme. i get the lastest bios for my mainboard, when i try out with the memory settings, i just get erros on memtest 1.51 , i change the memory up to 3.6v without results, the processor too. i want someone tell me how to configure the best setting as posible on the genies bios. also sometimes i get power off inmediatly after i save the new bios settings. it's normal.
Please if anyone had good experience setting up this memory with this mainboard, up me the settings with details. for the processor and memory
Specs:
AMD 64 3500 0.9 WINCHESTER
DFI LAN PARTY NFORCE 4 SLI-DR
2-6600GT CHAINTECH 128MB EACH ONE SLI MODE
512X2 OCZ PC4000 VX
not man, just when i oc to 11 x250 or 10 x268. any speed behond the 235 i get erros on memtest.. but the most interesting think is that always in the 98% of the case the error occured on 40% to 45% of the test. If you have some experience tweaking the memory on the genie bios or on the cpu step.
If you get errors at 250Mhz 2-2-2-7, then RMA it. If it's higher than that, then you can't do anything.
well the think is at 10x250 the test it's completely fine the main problem if i overpass the 250 or 11x250. it's imposible to get it stable.
