DFI Lan Party and UV colors question
First, do the Ultra Violet colors on the board only show up under a black light or will they glow even when all I have is Cold Cathode or even without Cold Cathode Lighting (Blue)?
Second, there is a problem recently on the DFI boards not being able to use PAT with all four banks of memory filled, is this a bios or hardware problem? And will it be fixed?
Originally posted by: Viper96720
It'll look better with a black light. That is what's used in the pics showing it glowing.
How exactly will I be able to get a black light in my case? Do I just get Clod Cathode thats black?
Also, I'm going to want to have a Blue Cold Cathode light in there to add color, if I use Blue and Black, will the colors show up brightly?
Get the UV cold cathodes... 😀 it should give off a bluish purple light... SVC 😀
i don't think you'd wanna use both a blue and black. the blue would over power it and your board prob wouldnt' get the "glow" of the black light that it should because the blue lights are just too bright.. mines so bright i rarely even use it at home as i keep all the lights off and when its on..its ... well, BRIGHT. i wish i'd have gotten a red light, that'd give it the perfect look i'm looking for. but ah well.. live (or should i say spend $) and learn. 😉
