DFI AD77 Infinity Memory Problems?
foxkm
229
I have a DFI AD77 Inf (KT400) and a stick of Micron PC3200 with my Athlon 1800+. In Sandra 2003, the memory benchmarks are roughly the same no matter what speed I set the memory to (266,333,400). The benchmark it it gives is like 1900 and 1780 mByte/Sec for int/float respectively. That is basically the speed that a PC2100 (266mhz) ram will give on other motherboards. I do have all my settings tweaked and verified that the memory is running at 333,400mhz when set to it. Anyone have any suggestions?
Thanks
Iron Woode
31,265
12,782
PC3200 ram is not standardized and performance is usually no better than PC2700 and sometimes worse. I won't even bother with PC3200 until a standard is set. I use PC2700 only and get excellent results. That DFI board (i have one) is a great board, not perfect, but the price was right for the features.
I would do a google search for reviews of this board. They all say it is one very stable board. The newer Northbridge versions overclock decently too.
