- Apr 23, 2001
- 10,572
- 0
- 71
If you're running Distributed Folding, it's probably not running as fast as it can!!
I've been checking my task manager (winxp and 2k) and noticed a little process called csrss.exe taking up 10-20% of the cpu consistently. Well, lo and behold it's the df client causing that.
The output to the dos window, the "fancy" graphics, cause csrss.exe to use cycles.
So bunker, you ask, how do I go about fixing this little problem?
Simple, if using dfGui, put a check next to Quiet Mode and stop and restart the client.
If using just the client or as a service, add -qt to this line:
.\foldtrajlite -f protein -n native -qt -rt
That's your friendly DF tip for this evening
