Hello gentlemen, thank you for taking the time to read about my problem.
For 2 years I have had 2 PCs hooked up to my home network in this configuration
Linksys DSL Modem > Linksys Router BEFSR41 > Ethernet Cable Coupler > PC1
Linksys DSL Modem > Linksys Router BEFSR41 > PC2
(The Coupler is necessary because I needed a longer connection and this particular wire was not easily replaced within the walls of my house.)
Now I need to connect my new ReplayTV and my brother's computer to the network, so I purchased the Linksys Switch EZXS55W. I attached everything in this formation:
Linksys DSL Modem > Linksys Router BEFSR41 > Ethernet Cable Coupler > Switch > PC1
Linksys DSL Modem > Linksys Router BEFSR41 > Ethernet Cable Coupler > Switch > PC3
Linksys DSL Modem > Linksys Router BEFSR41 > Ethernet Cable Coupler > Switch > ReplayTV
When I first attached the switch in the network, everything worked fine for 5 minutes, I even copied files from PC1 to PC2, PC3 and my ReplayTV hard drive to make sure that every connection was working fine. Then after ~5 minutes everything connected to the Switch loses its internet and network connection and cannot see any other device on the network. Unplugging and Re-inserting the cable from the Router to the Switch's Uplink A FEW TIMES will bring the connection back, but then the same situation occurs and a couple of minutes later nothing on the switch has a connection.
This problem has me stumped and I would greatly appreciate any help you can provide.
Thank you for your time,
Matthew
Matthew
