Device to input DVI/VGA
xtknight
12,974
Alright, I have an external HDTV tuner which outputs S-video and component (which both look crappy). It also outputs DVI and VGA, which when connected directly to my monitor looks stunning. I was wondering if there was any way to get a DVI or VGA signal and get it to my PC somehow (saving to a local file). Any ideas on a device that will do this? Preferably as cheap as possible (<$300), and if it's not cheap but does exist, at least I know it's possible to build. I'm not willing to get another (internal PCI) HDTV tuner at this point.
Matthias99
8,808
No. Not cheaply or easily.
You must mean composite looking crappy, as HD component (YPbPr) should look the same as DVI or VGA.
You would need a component or VGA to HD-SDI transcoder (not cheap), then an HD-SDI capture board (also not cheap), and a pretty beefy system with a lot of storage to hook it up to. This would essentially be the guts of a professional HD editing system.
The only cheap thing would be a PCI HDTV tuner, which you have already ruled out in your OP. If you have satellite, you can get a moderately expensive digital satellite tuner board (I think they're in the $600-700 range).
What would make the whole thing a *lot* easier are digital cable tuners that can take a CableCard and then tune HD cable directly. However, with content providers currently so nuts about piracy, this is *extremely* unlikely to happen anytime soon.
xtknight
12,974
Oh yes, I was talking about the composite outputs. I do have YPbPr output on my Samsung SIR-T451 (ATSC/QAM tuner). Is there any way I can get YPbPr to my PC just like I feed the S-Video/composite through my ATI USB device? I realize bandwidth for saving DVI to the hard disk would require a hunky buffer since I calculated that's like 180 MB/sec for 1920x1080 HD video.
Composite-usually the paired-together yellow,red,white analog-quality cables?
Component-YPbPr (full HD quality)
Correct?
I am using over-the-air HD signals. And why would this be easier if I used cable instead of UHF? I won't totally rule out getting a PCI tuner, but I'd prefer to wait until that cable decryption stuff was settled. I don't want an internal tuner that only does antenna. At least my external box does unencrypted cable, and I don't think the HDTV wonder supports that (QAM) at all.
Thanks for the responses!
Matthias99
8,808
Originally posted by: xtknight
Oh yes, I was talking about the composite outputs. I do have YPbPr output on my Samsung SIR-T451 (ATSC/QAM tuner). Is there any way I can get that to my PC just like I feed the S-Video/composite through my ATI USB device? I realize bandwidth for saving DVI to the hard disk would require a hunky buffer since I calculated that's like 180 MB/sec for 1920x1080 HD video.
Like I said, you could get an HD component->HD-SDI transcoder and capture board (and software), but that's easily a couple grand. If you find it for cheap, rest assured that you're looking at the non-HD variants of this equipment.
Theoretically, capturing from HD cable should be a snap, but content providers won't allow it. There are no PC-based capture boards that will take a CableCard (to allow decryption of HD cable content).
xtknight
12,974
Hmm, does quality of S-Video cables vary? I have my HD tuner sitting right next to my S-Video input box ("ATI TV Wonder USB 2.0"). So I need a short high quality cable. Right now it's quite long, and it's just the one that came from my HDTV tuner box. Also is it true that S-Video only supports up to 480i/p? I wonder why these YPbPr->SDI things are so expensive. No demand?
I take it there probably won't be any internal PCI HD tuner cards that support encrypted cable?
Matthias99
8,808
Doubt it will make much difference (it's better than composite, but that's about it). You actually can't even do 480p over component or S-Video.
It's specialty equipment used for broadcast-quality HD video editing. They can charge as much as they want (practically). It's not like movie studios and television networks are going to scoff at a couple grand here and there.
xtknight
12,974
Alright I'll get an internal card so I can get the MPEG-2 transport stream which should be even better and the HDTV wonder will hopefully be <$100 soon. But thanks again.
