My device manager shows Plug and Play Monitor and shows Viewsonic PF790........how do i get rid of the Plug and Play monitor..........everything is working fine just would like to get rid of the PNP in the device manager.
Try going in safe mode and remove them both from device manager,when you reboot it should detect your plug and play monitor and have just one listed in device manager.
