I have a Gigabyte motherboard (X38-DQ6) which officially supports a FSB of up to 400 MHz (although it can easily and reliably go as high as 475 MHz). So setting the FSB to 400 MHz means that my Intel Core 2 Duo E8500 which normally runs at 333MHz is overclocked and with a multiplier of 9.5 means it will "sing" at 3800 MHz rather than at a stock 3.16 GHz. All fine so far.
I also have 4 GB of Crucial DDR2-1066 (PC2-8500) RAM which can run at either 800 MHz (5-5-5-18) at 1.8v or 800 MHz (4-4-4-12) at 2.0v or 1066 MHz (5-5-5-15) at 2.0v.
From what I have seen with benchmarks (UserBench Encode 2009), they are directly related to increases in CPU speed with barely significant increases noted after tightening memory timings or increasing memory frequency.
To date, I haven't looked for a correlation between benchmark results and pure increase in FSB speed (whilst keeping CPU speed fixed by way of the multiplier), so I'm unsure what raising the FSB speed to 450MHz would do in that regard?
So my question is, what is the bottleneck in such a system (FSB, CPU, RAM?) and what configuration(s) should I implement for the memory with regards to RAM:FSB divider, frequency, timings and voltage for
1) best performance and 2) most stable and least heat generation (two different objectives)?
Because in theory, memory run at 533 MHz can process 8.5 GB/s, compared to memory run at 400 MHz which can only transfer 6.4GB/s so running the RAM at 533 MHz should be a good thing right?
Thing is, it makes a barely measurable performance gain in the benchmarks.
Any advice very welcome and if you know of any good articles on this topic, I would really appreciate any pointers.
Thanks
Thanks
