Dev-C++ Issue: DOS Window closes way too fast.
CKTurbo128
I'm not sure if this goes in OS or this forum, as it relates to both. Anyhow, this is somewhat embarrassing to ask, but in Windows XP Pro., how do you change DOS execution options? I'm currently using Dev-C++ to code some simple C++ programs and does output through DOS. However, the DOS window closes immediately after the DOS program finishes executing, so I can't see any of the errors or outputs generated from my program. Is there a way to keep DOS windows open even after exeuction has finished?
You can launch you program from the command prompt (Start Menu -> Accessories -> Command Prompt) or add (I think) getchar() at the end of your program so that it waits for a keystroke before closing.
