Deus Ex widescreen tool problem.
Status
Not open for further replies.
AmonAmarth
I posted a question on the sticky for this, but no one's responded at all. So I'd thought I should make a new thread in that case.
What I posted on the sticky:
Sorry to bump this old thread. But I've got a problem. This is for Deus Ex 1, retail version. I have an Nvidia surround setup, at 5760x1200 on Windows 7 64bit.
When I try to run the utility at this directory (driveletter: DeusEx\System), it gives me:
And when I try to run it at this directory (driveletter: DeusEx), it tells me that my aspect ratio needs to be 16:9 or 16:10 and gives me this:
All of the files in the System folder do not have the Read Only box checked, they are all unchecked.
Now, I noticed that in the main DeusEx folder, all the folders inside of it are set to Read Only. The problem is, when I try to uncheck any of them (including the general Deus Ex folder), hit apply, then okay, and go into the properties again - the folder goes back into being Read Only.
I don't know if that will have an impact on the way the utility works. But if the folder(s) is not a problem, then I don't know what is. All I'm trying to do is to get my UI/HUD elements to the center monitor. Any insight?
I recommend you PM the guy who created the tool: http://forums.anandtech.com/member.php?u=243000
Anandtech Moderator
KeithTalent
Status
