That's what I originally said.
But I also partly misunderstood the question, so I decided to retract my comment.
I get very suspicious when they have a post count of 1, and it sounds just like a teacher question, with NO explanation as to WHY they want the answer.
But a better way, is to use a current clamp meter (if you have one, can borrow one, or afford one, they are NOT very cheap, but not that expensive either).
A clamp meter means you don't need to disconnect the wiring.
