... detected a controller error on \Device\Harddisk2\DR4
HOSED
658
The driver detected a controller error on \Device\Harddisk2\DR4. This is happening repeatedly when I use my external USB drive for backups. IT is a Seagate ST9500420AS 500GB notebook drive inside Vantec NexStar 3 2.5” SATA to USB 3.0 External Hard Drive Enclosure - See more at: http://blog.testfreaks.com/review/e...al-hard-drive-enclosure/#sthash.FyaBzmcY.dpuf
I am using a 3.0 cable from the enclosure to the Sager in my signature Smart DATA: note all of these have a green indicator before them in HWINFO64
[01] Raw Read Error Rate: 117/6, Worst: 100 (Data = 154779763)
[03] Spin Up Time: 97/85, Worst: 97
[04] Start/Stop Count: 100/20, Worst: 100 (Data = 121)
[05] Reallocated Sector Count: 100/36, Worst: 100
[07] Seek Error Rate: 100/30, Worst: 253 (Data = 831687)
[09] Power-On Hours/Cycle Count: 100/Always OK, Worst: 100 (Data = 47)
[0A] Spin Retry Count: 100/97, Worst: 100
[0C] Power Cycle Count: 100/20, Worst: 37 (Data = 119)
[B8] End to End Error Detection Count: 100/99, Worst: 100
[BB] Reported Uncorrectable Errors: 100/Always OK, Worst: 100
[BC] Command Timeout Count: 100/Always OK, Worst: 99 (Data = 10)
[BD] High Fly Writes 100/Always OK, Worst: 100
[BE] Airflow Temperature / Exceed Count: 65/45, Worst: 52 (Data = 35.0 °C)
[BF] G-Sense Error Rate: 100/Always OK, Worst: 100 (Data = 1)
[C0] Power-Off Retract Count: 100/Always OK, Worst: 100 (Data = 34)
[C1] Load/Unload Cycle Count: 100/Always OK, Worst: 100 (Data = 987)
[C2] Temperature 35/Always OK, Worst: 48 (Data = 35.0 °C)
[C3] Hardware ECC Recovered: 46/Always OK, Worst: 43 (Data = 154779763)
[C5] Current Pending Sector Count: 100/Always OK, Worst: 100
[C6] Off-Line Uncorrectable Sector Count: 100/Always OK, Worst: 100
[C7] UltraDMA/SATA CRC Error Rate: 200/Always OK, Worst: 200
[F0] Head Flying Hours: 100/Always OK, Worst: 253 (Data = 35)
[F1] Lifetime Writes from Host (LBAs Written): 100/Always OK, Worst: 253 (Data = -833298529)
[F2] Lifetime Reads from Host (LBAs Read): 100/Always OK, Worst: 253 (Data = 110025349)
[FE] Free Fall Protection: 100/Always OK, Worst: 100
Eventually I was able to get the backup to complete. Anyone have any insight? Thanks!
Burpo
4,223
473
Not Seagate's best drive from reviews I've read.
Cons: Mysterious I/O Errors and freeze ups
Cons: Frequent read/write errors and BSOD just 4 months after the warranty
Cons: Drive failed in 15 months. Unrecoverable read errors. Can't even get it to work long enough to back up important data.
Cons: The drive worked great for a few months, then failed out of nowhere.
Cons: It failed on my Sony Vaio after 1 year 2 months of service.
HOSED
658
Thanks Burpo ... I have a plan, I will remove the Seagate HDD from the enclosure +swap the drive into my ASUS (which has 2 drive bays). Then I will do some extensive testing to rule out an issue with the drive enclosure.
Agreed this drive is not on anyone's recommended list!
