- Sep 28, 2002
- 226
- 0
- 0
Howdy. My system is in my sig. Now here is my story:
I have learned a VERY important lesson over the last couple of months: NEVER buy $40 Kingston value RAM for a DFI board (Initially I thought it might be OK, because I heard so many people here say that using value RAM works reasonably well, but I guess in my particular system it does not)
For the last 6 weeks or so, since I build my rig, I have been getting dozens of BSODs when I am doing just about anything. They always come out of nowhere and never seem to be reproducable -- sometimes referencing network drivers, sometimes sound card drivers, and sometimes just windows files. I tried the standard techniques: take out all hardware, safe mode, safe BIOS settings, etc., to no avail.
However, yesturday I did a MemTest (the prog is built into BIOS -- nice thing about DFI), and in about 15 mins it brought up 2500+ errors! I did another two quick 15 min tests with the same result, with more errors each time I did the test. I then tested each module individually by putting only one stick into slot 2 (single channel mode). I did a 1-hour MemTest on each stick, each with no errors at all. This lead me to believe that the sticks work fine individually but wreak havok when in dual-channel mode.
Thus, I took the RAM back to my computer store and exchanged it for a dual-channel kit instead -- Kingston HyperX 1GB. The first thing I did was do another MemTest. I ran the test for 3 hours, and produced no errors at all. However, at that point, the DFI tech support finally responded to my email and said that Kingston is generally not recommended for DFI boards. He gave me this link: Link
Now, I am thinking maybe I should exchange my HyperX 1GB (though it past Memtest, I have not had three months to use it) for one of the modules recommended, just as to play it safe and avoid issues which my pop-up another two months down the road. However, I don't have access to most of the modules mentioned. My store only sells the following: My local store
However, the info on the link that DFI sent me is somewhat over my league. I have narrowed down my choices of RAM to the following:
Corsair 2048MB TwinX PC3200 CAS 2 Dual Channel Kit ($309 CAD)
OCZ 1GB PC3200 Gold Edition 2-2-2-5 Dual Channel DDR Kit ($199.95 CAD)
OCZ 2GB PC4000 Gold Gamer eXtreme XTC Edition Dual Channel DDR Kit ($269.95 CAD)
Mushkin XP4000 Xtreme Performance Black Series DDR SDRAM, 2GB Dual Pack ($289.95 CAD)
From what I gather PC4000 has higher timings, but is more overclockable and has more selection when getting 2GB Kits. PC3200 has lower timings, but is not so good when getting a 2GB kit.
Now I know by looking at my sig, you would probably think that the system I have is crying to be OCed, and you would be right. I origially planned my rig to get into learning OC at some point in the future, but after the numerous BSODs I have been having at stock, and reading through all this confusing info about CAS/RAS, I have decided to lay off it for now. Aside from that I did manage to get my GTO2 operating at a X850XTPE, but OCing a CPU with a DFI board is very confusing. Added to that, I cannot seem to get my CPU temp to run cool at stock -- it still idles at 45C despite a recent application of AS5 on it, and a resonably good TT Tsunami case. So I am going to set OCing aside for the next 6 months or so.
Anyway, I just wanted to know, given that I plan on shelving OC for a while, what would be the best RAM to get. Sorry for the long post, I wanted to say as much history as I can so someone here can give me advice on what to do. I am now at the point of having my mind and money drained, repeatedly buying components that aren't compatible. Actually, I kind of wish I just spent a few more bucks on the ASUS Cool-Pipe board instead. DFI seems to be very finicky about what is inside your system...RAM or a PSU rail that is a little off voltage and it seems to complain, but I am kind of stuck with this mobo now.
