Desperately need tips on applying thermal compound!
MDesigner
OK, I've got my computer case opened and I'm ready to try this for the THIRD time. Check my rig details (link in my signature) to see my system stats. Basically, I have an Alpha PAL6035 w/ Sunon 24cfm fan. ASUS PC Probe reports the CPU temp as 61C when doing minor tasks. I just ran 3D Mark 2001 and Quake 3 Demo, and it shot way up to about 70C.
So, hopefully the third time is the charm. I will say that the bottom of the Alpha heatsink is almost a mirrored copper finish, so I assume I need a very very tiny amount of thermal compound. I first used this cheapo grey crap that came w/ the heatsink, but I was told it's silicon based and it sucks, so a friend of mine loaned me a white colored compound he says is lead-based. Here are the details on the compound. It's by Thermalcote. Its properties are below.. I'm typing them exactly as they appear on the tube, because I don't know what these notations mean.
Color: opaque white
Temperature range: -40F to 400F
Btu * ft
Thermal Conductivity: 0.43-----------------
Hr * F^2 * F'
Dielectric Strength: 300 v/mil
Volume Resistivity: 4 x 10^14 ohm-cm
Solvent: acetone
So you can judge whether it's good or not.
As I said, the bottom of the PAL6035 heatsink is VERY smooth and shiny, and I read somewhere that if the heatsink looks like that, you should use as much compound so it looks like a translucent haze. I can tell you that last time I put this stuff on, it was definitely an opaque white coating on the CPU. Perhaps I put too much.
OK, I just tried installing the heatsink again. Someone asked previously if I installed the clip on correctly, so this time I installed it "the other way" (which IS the correct way? one side of the clip is short and has a swiveling piece on it, the other is long and looks like a squared off triangle). I still get the same results, about 60C idling.
What am I doing wrong here?!
By the way, what convinced me to try to fix this is, my computer locked up on me during an intensive 3D demo. 🙁 I'm very sure the CPU is the cause, not the video card. At the time of lockup, it was close to 70C!
