Desperately need C help
Bluga
Banned
Nov 28, 2000
4,315
This string copy works:
strcpy((char *)task->data, "a" );
But why doesn't this work??
i=1;
strcpy((char *)task->data, i );
**note task is a structure and data is pointer to void.
stndn
1,886
strcpy only copies one string to another
in your first case, it works because "a" (with the double quote) is a string
in the second case, it doesn't work because i (or 1) is an integer (or so i assume, based on the value you assigned to the variable i)
however, if you use
strcpy ((char*)task->data, "1");
i'm sure it will work...
-1036-
RSMemphis
1,521
Well, there is also a trick you can use.
First of all, do you want it to contain a binary one, or the character one (those are two different things!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!)
If you want a binary one, it's easy.
If you want a character one, you have to add 0x030 (hex 30 = the character "0") or 48
and then you can use a trick. A string is anything NULL terminated. Any integer (they ARE at least 16 bit) are NULL terminated if smaller than 256.
But you again need a pointer (a string variable is always a pointer)...
you could do
i=1;
strcpy((char *)task->data, &i );
or
i=1;
i+=0x30; // alternatively i+=48;
strcpy((char *)task->data, &i);
It's kinda ugly, but it will work.
Edit: fixed the fact that ; ) will be made a ;) when written together.
RSMemphis
1,521
The reason why you get the segmentation fault, btw
It interprets i as a pointer (you probably got a warning that the compiler recast i.... Don't ignore warnings)
Since i=1, you address some very early memory, where mostly OS stuff resides... OS no likee...
Argo
10,045
If you want to copy '1' as a string you can use sprintf function.
int i = 10;
sprintf(task->data, "The value of i is: %d", i);
Upon completion task->data will contain: "The value of i is: 10"
