- Nov 19, 2012
- 127
- 0
- 0
I keep getting DPC latency spikes up to 200k ns. I keep getting audio/video stutters as well. I tried disabling dvd drives, uninstalling asmedia sata drivers, updating bios, different graphics card. stutters in game as well as on desktop. I notice it when I'm watching videos online or playing video games. A lot fo the times I will also see a latency spike, but won't get audio/video stutter, at least it wasn't noticeable.
msi gd65 z77 1155
corsair vengeance low profile 2x4GB 1600
antec 750 w psu
7950 radeon hd msi tf3
120gb ssd corsair force (was open box item)
1tb hdd wd caviar green
16x dvd +- rw
v6 gt cpu heatsin
i5 3570k oc'd to 4.2ghz @ 1.2v with pll voltage set to 1.65v
Here's results from latencymon and dpc latency checker:
msi gd65 z77 1155
antec 750 w psu
16x dvd +- rw
v6 gt cpu heatsin
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:17:08 (h:mm:ss) on all processors in the system.
SYSTEM INFORMATION
Computer name: INTEGRATED-PC
OS version: Windows 7 , 6.1, build: 7600 (x64)
CPU: GenuineIntel Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Logical processors: 4
Processor groups: 1
RAM: 8135 MB total
CPU SPEED
Reported CPU speed: 3400.0 MHz
Measured CPU speed: 2654.0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED KERNEL TIMER LATENCIES
Highest measured kernel timer latency (µs): 13311.990459
MEASURED SMIs AND CPU STALLS
Highest measured SMI, IPI or CPU stall (µs) 0.903508
REPORTED DPCs
Highest DPC routine execution time (µs): 280.895882
Driver with highest DPC routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.069181
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.204425
DPC count (execution time <250 µs): 3591701
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 2
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED ISRs
Highest ISR routine execution time (µs): 42.369706
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.016853
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.033934
ISR count (execution time <250 µs): 1284455
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: none
Total number of hard pagefaults 5790
Hard pagefault count of hardest hit process: 5255
Highest hard pagefault resolution time (µs): 99756.831765
Total time spent in hard pagefaults (%): 0.042125
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 13.070075
CPU 0 ISR highest execution time (µs): 42.369706
CPU 0 ISR total execution time (s): 1.263310
CPU 0 ISR count: 1250353
CPU 0 DPC highest execution time (µs): 280.895882
CPU 0 DPC total execution time (s): 7.131256
CPU 0 DPC count: 3222032
CPU 1 Interrupt cycle time (s): 2.249077
CPU 1 ISR highest execution time (µs): 13.662647
CPU 1 ISR total execution time (s): 0.105829
CPU 1 ISR count: 27592
CPU 1 DPC highest execution time (µs): 218.047647
CPU 1 DPC total execution time (s): 0.726019
CPU 1 DPC count: 205628
CPU 2 Interrupt cycle time (s): 1.819085
CPU 2 ISR highest execution time (µs): 15.563529
CPU 2 ISR total execution time (s): 0.020229
CPU 2 ISR count: 5030
CPU 2 DPC highest execution time (µs): 169.065294
CPU 2 DPC total execution time (s): 0.342103
CPU 2 DPC count: 94560
CPU 3 Interrupt cycle time (s): 1.449483
CPU 3 ISR highest execution time (µs): 16.197353
CPU 3 ISR total execution time (s): 0.006352
CPU 3 ISR count: 1480
CPU 3 DPC highest execution time (µs): 170.401765
CPU 3 DPC total execution time (s): 0.208604
CPU 3 DPC count: 69483
