I noticed this starting to happen two nights ago. My computer will be running fine and then it will just freeze. Ctrl+Alt+Del doesnt do anything, and I have to push the reset button. It then boots up and works fine for a while and locks up again. I had just upgraded to Windows XP Pro a few days before so I decided to go ahead and reinstall it. Part way through the installation it locked up again. I tried reformatting again and installing Windows 2000 Pro, but got the same results. I then tried XP again and it still locks up after 1-2mins of installation. I dont think I will even be able to finish the installation due to the fact that I have to restart after 1 minute. Someone please help me!
Here are my system specs:
AMD Athlon XP 1900+
Abit KR7A
256mb Crucial DDR
PNY Geforce4 TI4400
Maxtor 40GB 7200rpm
Netgear FA310TX NIC
Hercules Fortissimo II Sound Card
AMD Athlon XP 1900+
Abit KR7A
256mb Crucial DDR
PNY Geforce4 TI4400
Maxtor 40GB 7200rpm
Netgear FA310TX NIC
