Hey guys.
I've read and searched just about anything I could find with any relevancy to my problem before burdaining you with another thread. I'm f*ck*ng dying here, trying to solve this problem without getting a refund for the card, cause I really love 3D games and want the best I can afford... any help will be highly appreciated!
The fact is, I've been trying to deal with this problem for about 4 months now, and it just seems to be getting worse somehow... (?)
I've even done an RMA and waited 30 days to get a card back. Could be that I got the same card, except the idle-temperature for the GPU is 10celcius higher after the RMA!
The idle temperature in the summer for the GPU was ~54c, and now, in the winter, after the RMA, it is ~62c!
The problem is with the overheating of the 6800 card.
My computer is a music-studio computer, and I'm using a dual-boot: one for the music, and one for the
internet, games, etc.
Doom3 has had no problems whatsoever, but while running Beyond Good & Evil, the GPU has crossed the 90celcius boundary within ~4 minutes, and I am concerned that if the 6800 burns out, it might damage the studio-computer or the sound card!
Here are the details while running BG&E:
ambient: ~14c
CPU: ~35c (fan @ ~3500RPM)
MB: ~30c
PSU: not-PFC, single-fan, 420w, not-the-best at all (Asus-probe shows it is stable).
Case has 12centimeter fan pointed toward the outside.
6800:
NO-overclocking neither at present nor at past: clock is 350mhz GPU / 1000mhz RAM.
Game ran @ 1024/768, truecolor, 100hz refresh rate, maximum graphics options, no blur, no antialiasing.
6800 BIOS: 6800 bios 5.40.02.15 (I have searched for Nvidia bios updates but have found none anywhere, maybe they exist but I don't know how to find them..)
MB BIOS: 1.01 (I have the 1.19 update ROM with AFUDOS.exe, but I've never updated a BIOS before and I'm afraid to try the update in case it harms the studio-computer's boot that cannot be tampered with...)
AGP aperture at 256MB.
"Fast-writes" in my BIOS: I can't find it so I couldn't try to turn it off.
Software:
Windows XP sp1a,
Nvidia drivers 66.93
Asus enhanced driver 1.3
Smartdoctor 4.54
Another issue is that I can't find the Nvidia "temperature-settings" in the 6800 tab under "display>advanced", so I can't tell if it's just a smartdoctor issue.
I've tried just about anything - opening the case and pointing a fan at the card to see if the card shows lower temperatures (it does - it goes down slowly...), cleanup tools after uninstalling drivers just to reinstall older + newer drivers, coolbits (to see if the "temperature-settings" appears - it did not), except for a few things:
Adding another 12 centimetre fan on the front of the case: this will cause noise in the studio, and will probably just lower the temperature 3-5 celcius... this is not it, I believe. Nevertheless, I have ordered such a fan and am expecting it to arrive in a few days.
The Asus technician I'm in touch with says I should re-RMA the card: But what if they find no problem with the card (as I'm afraid they will not)?
I haven't tried buying a thermaltake pfc PSU I've had my eye on: but what if the problem persists, and I end up spending $50 for nothing?
Formatting the HDD: haven't tried this yet, but I will if you guys tell me to... 🙁
The whole point the way I see it is the idle temperature of the card: 62 celcius at windows while MB is 30?! Come on!! Which of you guys sees this as normal?
I am so pissed off at Asus and Nvidia and the whole world, I feel like breaking the stupid card in two!
Except I really WANT IT TO WORK... 🙁
ambient: ~14c
MB: ~30c
6800:
Software:
Windows XP sp1a,
Smartdoctor 4.54
