palindrome
Bought a Hakko 936 in order to replace a broken A/C Power adapter on a laptop motherboard. This unit goes up to 900 degrees, but doesn't seem to be enough to make the solder bead. Any idea what temp you need to melt solder on these motherboards? And if I need a really hot iron, I could use some recommendations. Any suggestions are welcome and appreciated.
Update 1/30: I got the connector off, but 3 of the 6 places have a broken off part of the connector in it and I cannot get it out using a qwick. I heat it and its like nothing happens. Any suggestions?
