narutofan36
Hello,
This computer has been working fine but today, I decided to run some windows update. Upon shutting down and reopening, the computer turns on but no monitor! I do not see the keyboard lights going on either.
The GPU fan runs at full speed but it always did that after I installed truecrypt (after I enter the password, the gpu fan goes back to normal speed) so I'm not sure if this is an indicator of any sorts.
I made sure everything was plugged in, took the motherboard battery in and out, but still does not work.
After opening and shutting down the computer a bunch of times, nothing works. SOMETIMES, when the computer starts, the gpu fan goes at normal speed but still no monitor signal.
Any help?
Any help?
