Desk top back ground picture problem
cirocorby
Could any one tell me why my desktop background picture dont display ,if i select the picture i want as as backgroundit shows fine after i restart i lose my picture and need to set picture again what a pain! iam running windows XP Pro service pack 2 and help would be gratefull?
JarredWalton
53
Does it do that with *any* background image, or only the one you currently want to use? It could be driver related, it could be a problem with the image (not too likely), or you might have some other junk on the system causing problems. Since I don't feel like going into much depth right now, you could try reading about MalWare and taking the suggested steps to see if that helps.
http://arstechnica.com/articles/paedia/malware.ars
GunDog
497
Place the images you want to use in your windows directory, c:\windows. Then use the image you want.
