- Feb 18, 2001
- 30,990
- 5
- 81
Hey guys. I am actually going to start a topic that belongs here
This is the story. I will be building my house sometime next year. I am currently designing it. This is something I want to do to cool the huge wattage that my fleet puts out.
Currently, I have 11 computers running in a 14 x 16 room. It gets extremely hot in here. In the beginnin of the year I touched on 120 degrees or so. I ened up adding a though the wall 5000 btu AC unit to help cool the room down. It did make a huge difference, but it never turns off. Sucking up the power
This is my plan. I want to water cool this fleet. I want to cool it using the naturaly cool ground. The water circuit I have in my head goes like this:
Water is held in a tank 4' or so undergound. From there, it is gravity fed into my basement, where the cooling water would be directed to each computer. From the computer, it would go into a water pit like a sump pump has, but much larger. In that pit will be 3 pumps that will raise the water up to 18" below ground level, and though a long series of pipes. Those pipes would be in a grid like patern ( smallest possable area wise )
After flowing though the grid patern ( where it gives up its heat to the gound ) it would return to the tank about 4' below ground.
I am looking to disapate somewhere in the area of 10,000 watts. ( I disapate somewhere in the area of 3k now, and I have to plan for the future
I was looking for some imput on pipe diameter, location, and area of the "field" that would be needed. Remember to think 3d as I can go up ( within 18" of gorund level ) with no real depth limit, but 10' I would like to be max as that is the same height the basement will be excavated to.
I was assuming black or galvinized pipe for the pipe in the gound, and PVC for interior runs. ( not sure yet, as I may get a voltage difference )
Oh, and the pumps I have selected will pump about 1200 GPH @ a 10' head.
