Desert Combat Help
dpm
1,513
I'm guessing that you are using an Nvidia graphics card, and haven't updated your drivers recently.
I had the exact same problem - gf4 ti 4400. I downloaded the latest drivers, and the problem went away.
onelin
874
funny, I've heard stories of downloading the latest drivers CAUSING this. State your driver version, try new ones, but chances are trying old ones might be what helps. I'm using the 44.03's just fine.
us3rnotfound
5,334
go to nvidia.com hard, but before that, hit driver heaven for the driver cleaner utility, unless you don't want to be a hardass like me, just get teh 53.03's and install them over, making for a messy installation of software, you idiot :disgust:
TheBoyBlunder
5,742
You're running an nvidia card and the 52.16 drivers. Upgrade to the 53.03's or downgrade to the previous drivers. The 52's are crap.
mrlayance
366
I installed drives from NVidia once and my card did not perform aswell. I will just wait, Desert Combat is the only game that does this...
