Dependency problem in SUSE 10
jfunk
1,208
I have setup a couple repositories for yast, including a mirrors.kernel.org, packman.inode.at, and scorot rpms.
When I attempt to install the Novell Client (which is located in a folder on the HD), one of the components comes up with a Dependency conflict:
libbfd-2.15.90.0.1.1.so not available
Where can I get this package from?
Thanks much.
j
edit:
Ok, I did this:
rpm -ql binutils | grep libbfd
/usr/lib/libbfd-2.16.91.0.2.so
So it appears I have this thing, just a newer version. Can I just tell yast to ignore the dependency and install anyway, or are these things very concerned about the particular versions of files?
Sorry, I haven't a clue what I'm doing....thanks.
j
n0cmonkey
42,936
Depending on how it's looking for the file, you could try linking the newer version to the older version. Might work, might not. :p
xtknight
12,974
rpm --nodeps
will ignore dependencies
to link it:
ln -s /usr/lib/libbfd-2.16.91.0.2.so /usr/lib/libbfd-2.15.90.0.1.1.so
edit: sorry had the ln -s command reversed. the older version goes last because that's where you're 'creating' a link.
jfunk
1,208
OK, linking it didn't make any difference as far as the error is concerned.
Should I try telling to to install anyway, or is that pointless if it doesn't recognize it's required components?
Thanks again.
j
n0cmonkey
42,936
I wasn't sure that would work. I didn't know if they'd check for the existance of the file, or check the rpm database or something. :(
You can try installing it anyways.
jfunk
1,208
OK, I forced the install anyway, but no go.
When I attempt to start the client, it fails saying that file does not exist.
Is there a way I can downgrade by version of binutils to match the one it's looking for or have both versions installed??
j
n0cmonkey
42,936
Messing with binutils can be dangerous.
If the symlink doesn't tame the client, I'm not sure what will. Any updates to the client?
jfunk
1,208
Not yet. Apparently "they" are "still discussing" an updated client for 10.0.
However, I was able to find a binhack rpm that somebody posted on the novell forums that gets around the problem.
Of course, after all this I finally get the sucker working and it turns out it doesn't support NDS. eDirectory only, which most of our old crap servers don't run.
Thanks much for the help.
j
