I have a few questions about my heatsink and fan combo. I currently have a SI-120 with a high speed delta triblade. For reference, I have this fan http://www.sidewindercomputers.com/de12trblhisp.html I have a custom built case and the fan is taking air diretly form the outside of the case.
Just checking on this one, but is the only difference between the high and low speed delta triblades the amount of power that gets to the motor? If both fans are running at 2000 rpm, are they going to be equally loud? Is the advatage to the low speed fan a softer (lower rpm) at the minimum start up voltage?
There does not seem to be a large change in temperatures between 7 and 12 volts with this combination of fan and heatsink. Is this normal? When I was researching the two products around christmas time, I did not see anything commenting on the fact that the SI-120 needs fvery little airflow.
Can I plug this fan into a dfi lanparty ultra-d motherboard header without blowing it out? I have heard a lot of conflict views on this one. Right now, I am trying to get rid of a fan controller while still being able to adjust the amount of ariflow moving through my case. I have found that even thyough the extra airflow does not help processor temperatures, it helps lower chipset temperatures.
Thanks
-OJ
Thanks
-OJ
