Me and my bro try playing it but it wont work, we both tried hosting nothing works, we have all the right protocols installed. www.novalogic.com has no support for network games.
Well make sure you are running at least version 1.0.0.23 I think thats it. Landwarrior had some issues with earlier versions and running server. I will try it at home tonight and see if I have any trouble.
