Delta Force freezes...I need help...plz
Echelon
109
Sometimes when playing Delta Force, It just freezes, doesn't respond anymore and I have to shut the game down in windows by pushing <ctrl>, <alt> and <del>. Then I have to reset my computer to get the game working again.
Is there anyone who has (had) this problem?? Is it common with this game?
My specs: Abit Be6-2, P3 550 katmai, 64Mb Ram, TNT2 M64 Cougar, SbLive!, win 98SE
Dx 7.0a and all latest drivers installed except for the TNT2 because the Det2 driver isn't working that great with some of my games
i need help plz...thank you
Klosters
You might think seriously about adding another 64 Mb of Ram. 64 Mb just isn't enough for SE.
LBM1A
107
You may want to run the Delta Force update and see if this fixes the problem. I had the same machine setup last year and played the game with no problems(64mgs of ram).. I have heard alot of problems popping up because of Directx 7.0 also. I always ran 6.0... I still play both DF and DF2 and have had no freezes with Directx 6.0.. :)
Echelon
109
okay...I'm going to add some more ram
Someone on hardwarecentral told me he had the exact same prob with DF when playing with 64Mb, when he added some 64Mb more, the problem was gone
DF update is already installed...maybe the problem will go away with Dx8...we'll see :)
thx
