Specs:
Epox 8K7A
with Delta fan (3 pin)
Just a second ago the Delta fan stopped on the CPU. We took the Delta over to another to another PC and it worked fine. Now, we tested a second fan (Taisol) on the PC in question and did the same thing, nothing. Lastly, we plugged the Delta into another 3 pin on the motherboard (for chassis pin) and it worked fine. So it seems like the CPU 3 pin plug has gone bad. What should we do from here?
Options:
Send the Epox back for a replacement
Find a 4 pin CPU fan
Others?
Any suggestions?
Epox 8K7A
Options:
Others?
Any suggestions?
