Does anybody have one of these boards and using a 6000+ RPM fan on the CPU fan Header or know if the header can take the power draw without burning out?
Just to be on the safe side, I'd rather use a 3pin to 4pin(molex) adapter. The Delta draws a lot of juice and considering the K75SA itself is picky on power
supplies, it may affect stability.
This is for a friend that wouldn't even notice if that LOUD fan went silent. I want it to alarm from Motherboard Monitor if it does. I'll try it on the MB header unless somebody tells me "that damn fan f'ed up my header".
Thanx. I can always count on the guys from Anand for honest advice.
