the 60x60x25 mm one.
The place where i can buy one, they say it should be attached directly to the PSU, in order to not harm the MB, is this true ?
My MB is a ASUS A7V133, can this MB handle that fan ??
it is generally a good idea to put fans that dont have a monitoring wire (yellow) onto the power suppy connectors rather than the motherboard. if it does have rpm monitoring, you might be able to do a solder job and still use the power supply directly
if the fan is >4 watts, i'd say definately dont risk the mobo.
<< it is generally a good idea to put fans that dont have a monitoring wire (yellow) onto the power suppy connectors rather than the motherboard. if it does have rpm monitoring, you might be able to do a solder job and still use the power supply directly
if the fan is >4 watts, i'd say definately dont risk the mobo. >>
Any mobo made after the Asus A7V can theoretically handle the power load for it, but I still wouldn't recommend plugging it into the mobo. Use the PS adapter.
The good news is that if you fry the mobo fan header, the RPM sensing pin usually still works! Go ahead and fry your mobo fan headers to your delight! I would not trust anything over 3W on a mobo fan header. What's the big deal with switching to a 4-pin? You can still keep the sensing wire plugged into the mobo if that's what you're after.
I used the Delta for a bit. At first had it connected to the motherboard, but under heavy cpu load I could hear the fan slowing down. Changed to 4pin and worked like a charm. Provided the lowest air-cooled cpu temps I've had to date, but LOUD!
