Dell with integrated NIC problem and DSL
laper
127
Wasup with this integrated NIC (on MB), will not work with
my DSL provider, otherwise fine on network and will
connect with the Cable company. Anyone have this problem?
John
Moderator Emeritus<br>Elite Member
Sounds to me like your NIC is functioning properly. You might want to call your DSL provider and check your network settings.
laper
127
I called DSL co., Its a known problem that this NIC will not work
with their gateway, they recommend that ppl don't buy a Dell computer.
ElFenix
102,393
8,552
doesn't work with their gateway? that... might just be the dumbest thing i've ever heard... ethernet is a standard, the gateway shouldn't care. especially with the intel integrated nic, those are some really good nics. maybe you should just go pick up a linksys 10/100 for $20 at compusa since the dsl people don't want to help.
