Overview from Dell:
he 1800FP is one of the first Dell UltraSharpTM flat panel monitors from Dell. It features a narrow bezel under 1" wide in midnight gray with Ion Silver colored buttons. With its thin 3.0" panel depth, the 1800FP fits well in space constrained spaces. The 250 nits of brightness and 350:1 contrast ratio deliver bright, and colorful images. The 1800FP is the perfect choice for customer's looking for a large flat panel display at an affordable price.
Tech Specs:
Viewable Size: Diagonal 18.1" (45.97cm)
Depth: 8.8" (223mm)
Height: 17.0" (431mm)
Weight: 17.2 lbs. (7.8 kg)
Width: 16.0" (406mm)
Dot Pitch: .2805mm
Environmental Parameters: Temperature:41° to 95°F (5° to 35°C) Humidity:10% to 80% (noncondensing)
Image Brightness: 250 CD/m2 typical, 200 CD/m2 minimum
Image Contrast Ratio: 350:1 typical, 200:1 minimum
Image Max H-View Angle / Image Max V-Vie: +/- 80° typical (Horizontal and Vertical)
Max Resolution: 1280 x 1024 @ 75 Hz
Power Consumption Operational: 50W - 55W
Power Consumption Operational ( Standby : 3W or less
Type: Active matrix TFT LCD
Response Time: 30ms
Product Highlights:
SXGA resolution (1280 X 1024)
Viewing angle of 160 degrees horizontal and vertical
18.1'' screen size
350:1 Contrast Ratio
250 CD/m2 typical
Digital DVI-D and Analog inputs
.285 pixel pitch
