Dell Precision 380 & 390 Post problem
Discussion in 'Computer Help' started by Michael Stout, Aug 28, 2012.
  1. Michael Stout
    Michael Stout Junior Member
    Aug 28, 2012
    Hello out there, I have these two 380 & 390 Dell Precision units that only gives one long error beep repeatedly. There is no video, I have tried each unit with installing harddrive and memory one at a time. The beep continued, then I removed each component one at a time to no avail. Thanks for you time and responses.
    #1 Michael Stout, Aug 28, 2012
  2. Loading...
    Similar Threads - Dell Precision Post Forum Date
    Dell Precision 5810 Computer Help May 24, 2015
    Dell Precision M4600 issues Computer Help Dec 4, 2014
    Dell Precision - stops during power on Computer Help Sep 17, 2014
    Dell Precision M6800 is not compatible with Windows 8.1 Pro x64 Computer Help Jun 13, 2014
    Dell Precision T3600 detects SSD as a SAS Computer Help Feb 15, 2013
  3. Steltek
    Steltek Golden Member
    Mar 29, 2001
    1,630
    On the front panel of both of the machines, there are four lights in the form of the numbers 1, 2, 3, and 4 (they are located between the headphone connnector and the USB port on the front bezel, slightly below both the network link light and hard drive indicator lights (in the image below, the "1" light is labeled as item 13).
    When you turn the machines on, are any of the numbers lit up in green? If so, specifically what numbers are on and what numbers are off on each machine?
    [​IMG]
    #2 Steltek, Aug 28, 2012
