Dell P911 19"monitor starting to blur
alighieri
65
This monitor is approx 3 years old and has just started to have a "wobble" on screen. It looks like the wobble caused by interference from another electrical device but I can not find one that could be doing this. Is there something I should be doing to fix this or is this just a sign that my monitor is starting the slow spiralling path o doom?
-I have checked Dell site for drivers, nothing new
-I have tried re-connecting the monitors cables
-Tried different electrical outlet
I am using a Gainward GeForce4 4200 64 Mb. Would it be worth it to see if this wobble is present wih the built in video?
Any help would be nice, thank you
edit: I was running monitor at 1600 x1200 at 75Hz and problem still there when I decrease resolution
Alighieri
egale
848
The easiest test would be to switch monitors and see if the problem happens with the other monitor. If you have onboard video, that would test your video card but I think the monitor test would be the easiest to do.
