Hello,
A friend has a Dell Dimension 8300 desktop which was in working condition. He recently moved to a new apt. and plugged his PC in and it didn't turn on - no response. I took a look at it and noticed the green power light on the MB, tested the power supply and it tested Okay. I unplugged all non-req'd components and still no response, changed the RAM, reseated all chips, remounted CPU/fan. and nothing!!!
For weeks, I failed to diagnose the problem!!!!
So then, I seen the exact same PC on eBay and got a good deal on it. I got the new PC in and swapped out the harddrives, ram and CD/DVD drive. So he basically had the same system. I then turned it on and bingo...it worked. So, I did some minor file cleaning and updating and then I re-booted it approx. 6 times without a hitch. Problem solved....Right!!!
So now I took it to his apartment to hook it up. I plugged it in and turned it on and nothing happened.....I tried a new Power cable and nothing. There are other components plugged into this same outlet in his house and they run fine.
I took the PC back to my house and tried to start it and nothing......I am lost as to what the problem is.....
Specifications
Model: Dell Dimension 8300.
CPU: Intel Pentium 4 with Hyper Threading 3.0GHz.
RAM: 2 x 1024MB DDR (2 Gb).
Hard Drive: 120Gb IDE harddrive
CD-ROM: DVD-ROM, CD-RW.
Floppy: 3.5"
Ports: (2) PS/2, Serial, Parallel, (8) USB, Ethernet, 5ch. audio, headphone.
Cards: VGA/S-Video/DVI, modem.
Any help would be greatly appreciated.....Thanks!!!!
Specifications
Floppy: 3.5"
