Not sure how to phrase all of my problem as I'm pretty clueless when it comes to this stuff. In short, I had a HD failure a week or two ago. My Dell was under warranty, so they sent a guy out to replace the drive. He comes with a Western Digital Drive (my original drive was a Maxtor), plops it in the computer, puts my Windows Installation CD in (says it has SP2 on it) and starts the installation process and leaves. The WD drive is listed in system info as a "WD800JD-75LSA0" if that helps any.
He doesn't hit F6 to load any drivers. The installation fails, so I go to restart it. Fails again. I call Dell support and they have me delete the partitions on the drive and start over again. Still don't load any drivers from a floppy. This time for whatever reason the install works fine. However, I'm getting these reoccuring errors in my event viewer and think there is some sort of problem with the HD. I'm skeptical that no drivers were loaded during the Windows installation because I went out myself and bought a new Maxtor SATA HD and installed Windows on it. The instructions had me dload some driver files to a floppy, which I then hit F6 in the Windows installation process to load these files. Everything works fine on that drive so makes me wonder why this wasn't done on the Western Digital.
Here is a link to the 2 errors I keep getting. They often come up in the log at times when I restart the computer, but not always. Another common time it sometimes comes up is around 6am. Only thing I could think of with this time was its when my AVG AV program scans. But again, doens't show up at this time every day so who knows.
http://i22.photobucket.com/albums/b350/dicedealer18/ClintERRORlog.jpg
Any clue on these errors? I noticed the one listed iastor.sys and I found that file in my system info. Here's a screen of this if anyone needs it:
http://i22.photobucket.com/albums/b350/dicedealer18/SystemInfo4.jpg
Is this looking correct to you guys? Should this HD show up in the IDE section as opposed to the SCSI section? My system BIOS has a Sata operation section. It has 4 options in it. Its selected to run in "RAID Autodetect/AHCI otherwise" mode. (I don't have RAID, btw). Other options include "RAID Autodetect/ATA otherwise", "RAID on", "Combination (SATA/PATA)".
Also, here is a screen of my HD info in the disk section of my system info. I'm still confused how it shows up in a port under SCSI, yet the HD doesn't show up in the SCSI section on the other screen.
http://i22.photobucket.com/albums/b350/dicedealer18/SystemInfo3.jpg
Again, any problem in what you've seen so far?? Finally, I don't know how to tell what my motherboard is, but here is a screen that maybe you guys can use to tell what it is. I understand and have read that certain motherboards need the SATA drivers loaded, others have them preloaded.
http://i22.photobucket.com/albums/b350/dicedealer18/SystemInfo5.jpg
I'm clueless on this whole thing. I want to believe my HD is working properly, yet I doubt I should be getting error msgs in my event viewer like this. And I'd like to finally get an answer to whether or not any additional drivers should have been loaded from a floppy when XP was loaded on this HD.
Any help anyone can give would be appreciated!!
