Dell 2405 with Radeon 9800 Pro?
Jackal30
12
Any point in getting the 2405 if i'm usng a 9800 Pro? Will it run 1900x1200 ok? And by ok, i mean without having to turn everything way down. Thanks.
Jackal30
12
Hmm, you are using a 9800 Pro? I can run WoW at 1600x1200 with almost everything turned up with no problems at all. Not sure why you can't go above 1280x1024.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
Kind of depends on some other factors too (like what games, what the rest of your system is).
I found 12x10 to be a good res for most games and then turned up settings.
I could do 16x12 too but I 12x10 with smoother naturally.
PurdueRy
13,837
4
WOW is more network intensive than graphics intensive. I am talking about in games that really stress the GPU and assuming that you want high framerates
