when im not in CS:S its fine but when i go to my games and click on css after a few seconds i get this high pitched sound comming from my monitor. i didnt get this untill i changed the resolution to the standard one 1920x1200
This is a known problem with the 2405 monitor. You will have to RMA it for another one, that is the only solution. Check the HardOCP forums for more info.
