**DELETE**K7T Pro2-A O/C Help Please
Badbry
Banned
Aug 14, 2000
250
No matter What I Do I Cannot Reach A Gig With This CPU/MB Combo...Is There Anybody Else That Has This Board,That Could Give Me Some Pointers?(I Am Using The Latest O/C Bios)The Memory Is Set To Cas 2 100mhz.
Thanks,
bryan
Duron 800@950 1.76v
Gladiator Lapped W/Delta
MSI K7T PRO2-A
256 Megs AVL PC-100@133
Geforce2 mx@190/190
8x8x32 CDRW
52x CD-ROM
40.8 GB Samsung HDD
D-Link NIC
300 Watt PS
__________________
CPU DIE #
D800AUT1B
AKCA0047VPMW
Z8041340759
CocaCola5
1,599
Try disabling AGP 4X, and stuff like bios/video caching. Use AGP manual mode instead of auto.
heng1028
1,792
come on
try increase voltage to 1.85 and see
what is your multiplier and FSB??
i has the same chip and mobo as yours 2 months ago
i can hit mine at max 1060 (10*103) but i want high FSB so i kept it at 1017 (9*113)
CocaCola5
1,599
Did you set the voltage to 1.85/3.45? Also try using this setting and let your computer sit in the cmos overnight at something more than 1G, I suggest (101-104)fsb X 10 see how far you can go, if possible do a even 100 X 10.5.
Badbry
Banned
Aug 14, 2000
250
I Got Almost A GIG!!!!(997.5Mhz)(35 Celcius As I Type) My FSB Is At 105 And My Multiplier Is At 9.5...If I Set It To 10x Or Anything Above,I Get It Booting Back At default(8x100)I Want To Just Do 10x100,But I can't
Bryan
heng1028
1,792
i think you have a multiplier issue Pro2-A
goto overclockers.com and they have a tip tp solve that problem
