I just installed the Catalyst 3.8 drivers for my Radeon 9800. After I did that I noticed that I had 2 monitors listed under the Monitor tab in Display/Advanced. They're listed like this
Default Monitor
Plug and Play Monitor
with "Default Monitor" highlighted when I open the menu.
Since "Default Monitor" was already selected I loaded the monitor drivers for it and now it lists as NEC Multisync FE2111SB which is fine. I was just wondering which of these monitors I'm suppose to set up as my active/primary monitor. Should I load the monitor drivers for "Plug and Play Monitor" as well and set it up as the monitor to use or leave things set up for the "Default Monitor?"
Also, I don't know if this matters but I have my video card hooked up to my T.V. with a s-video cable if that has any bearing (could that be the Plug and Play Monitor it's listing?).
Chris
Default Monitor
Chris
