Default memory speed for P5B Deluxe?
Jumpem
If I weren't to overclock at all what memory would I need... DDR2-533?
That's what I think, but newegg is showing FSB of 800. 😕
You have options...the chipset at default fsb has different mmory ratio options 533/667/800
take your pick.
take your pick.
Yeah, but stcok 1:1 would be 533.
Stock is whatever memory type you have installed. 1:1 is NOT stock if you buy 667Mhz memory.
Intel specifies 533/667/800 for memory speeds AT STOCK SETTINGS
There's a reason you have those options in the BIOS and it's NOT overclocking to run DDR2-800.
