default jumper settings?
QuantumPion
what are the default jumper positions for the evga 680i motherboard? there are two jumpers along the bottom of the board, one is for the cmos clear, but I don't know what the other one is for. I was messing with both of them and I'm not sure if I have them both in the default locations.
It does not. For the CMOS reset jumper, it says pins 2&3 is the default, but the pins are not labeled on the motherboard. There is no mention anywhere as to what the other jumper is for.
The numbers may be really small but should be there. Take a look at page 11 in the manual. that should be the correct position of the cmos jumper when running normally. I don't see any other jumpers?
Edit: The other jumper by the pci slot is most likely for turning the onboard speaker on and off....
ah ok, but what is the default position for that one? I don't see it mentioned anywhere in the manual.
