Default fan size for retail Athlon 4400?
Phos187
I'm assuming it's a 80mm but wanted to double check. Anyone know? I'm not seeing the size listed with the specs.
Having some temp issues and was going to order some new high speed fans for the case and cpu, forgot to take a look inside the case and double check before leaving for work
Sadly when the PWM readout hits 40 Celsius or higher I get crashing or system reboot. That doesn't strike me as high...
Desktop: Case: Cooler Master TAC-T01-EK // PS: :550W-Antec True Power 2 550 SLI ATX 2.01 // Mobo: DFI Lan Party UT nF4-D // Processor: AMD Athlon 64 X2 4400+ // Memory DDR(400)3200 2GB(2 PCS 1GB) OCZ DUal Channel Platinum // Graphics: eVGA Geforce 7900GT 256 // HD Western Digital Caviar RE WD2500YD 250GB 7200 RPM 16MB Cache SATA // Soundcard Audigy2 ZS //OS: Windows Media Center
