Dedicated audio PC
KBlair
I need to build a system specifically for recording, editing and burning audio. I've got the audio interface already, Tascam FW-1884, and it uses Firewire. It's been 3 years since I bult a system from scratch and I just don't have time to research all the diff chipsets and CPU codenames and what all.
So I'm asking for specific recommendations: CPU, motherboard, memory. I learn towards AMD but soley from a price standpoint. Budget is around $400. Stability is the most important factor. No overclocking here. Video doesn't really matter.
The current machine is an AMD Athlon 800 w/ 1gb ram which did fine while only doing one or two tracks at a time. We are now doing 8+ tracks and the machine is just not up to the task.
TIA
id look into a base skt 939 system say 3200+ deffinetly a gig of ram maybe a mobo with an integrated geforce 6100 card and i think i say a standard ata 300 gig hd western digital hd for like a hundred and change but i might of been on acid then so dont quote me on that you shouuld be around your budget maybe like 550 ish 400 is tight
Just the audio interface. The $400 is just for CPU/mobo and memory. I've got a case and a DVD burner that I'll reuse. I'll get 2 harddrives at least, one for performance and one for bulk storage. The harddrive money isn't included in the $400.
Oh, the monitor is one of those huge Sony 24" Trinitron tube monitors, so any builtin video will do fine. It would be nice if the mobo had Firewire, but I do have a Firewire card if need be.
Thanks
Thanks
You should be able to reuse the 1gig from the 1800 rig if its 2x512 PC2100 or PC2700 and just add another 2x512 relatively cheap for a total of 2gb. Ram speed isn't the bottleneck on A64 systems so the peformance difference between PC2700 to PC3200(current) is negligable.
I would recommend
Epox 9NPA + ultra $105
AMD X2 3800+ $295
The epox board is a really solid board and has 2 firewire outs, and all the other NF4 features
If your budget won't allow the X2 you can get an A64 3200+ for around $160, but I think the dual core would serve your purpose well.
You can buy the older style memory on ebay for cheap
512mb pc2700 on ebay
Oh yeah! You would need a cheap video card like an mx300 for $30
Thanks. That certainly would fit the bill, but I'd need to go with the 3200+ and use the extra cash for RAM. The current machine is an 800, not an 1800 🙂 so the memory work work, I don't think.
