Decided on a case & fan controller..
l Xes l
Banned
Ok.. i've been patrolling over the net for a while now... and finally decided on..
COOLER MASTER CAC-T05-WBA
http://www2.newegg.com/Product/Product.asp?Item=N82E16811119056
It's going to be air cooled.. so i decided to add a fan controller...
i've read some other threads regarding the fan controllers.. but i haven't heard much about this controller...
COOLER MASTER ALD-V02-UK
http://www2.newegg.com/Product/Product.asp?Item=N82E16813999157
I think controller will match the case pretty well.... anyone has experience on this controller?... any other suggestions?
The case only has one 80mm front and one 120mm rear fans...
Would i be able to connect to both of them with no problem?
Yeah, should be able to, though personally I leave my main rear fan connected to the MoBo, and let it control it. That way, I cant accidentally leave it turned down low and come back after dinner to a fried CPU. It also lets me view all my stats in PC-Probe (a utility prog for ASUS MoBo's).
You might want another fan in there somewhere, especially if your overclocking. Maybe in the side panel, over the CPU/Video Card.
RoD
nah... i'm pretty set on that fan controller... looks best out of the selections IMO.. plus not interested in those extra features.. 😛
Well if selection (and price IMHO) is what you are looking for, no better place to look than:
www.svc.com
door and knobs on fan cotrollers is a no-no. I have the aerogate 3. All I have the fan controller do is undervolt to 7v. If the fans you have are quiet than the controller is a pretty add-on that does little. Spend your money on a better PS.
