Decent small multimeter?
Muse
41,374
10,490
I have a Fluke, but it's big, heavy compared to my ~1/2 dozen Harbor Freight cheapies. Of course the Fluke is high end and it seems like you hear about them and nothing else when it comes to reliable multimeters. However, I have multimeters everywhere, in drawers upstairs, downstairs, one in the car and they are the Harbor Freight ones. But they are annoyingly unreliable. l suppose it's the dials not making good contact. Drives me crazy sometimes and I generally have the impression that I shouldn't rely on what the HF meters say. The Fluke never fails me.
90% of the time I use a multimeter it's to check on the state of charge of a battery, usually a AAA or AA, Eneloop or alkaline. Out at the car, it's the car battery.
Well, I'm wondering if I pony up more dough I can get me, say, 1/2 dozen small/light multimeters whose readings are reliable. Any ideas?
Charmonium
10,654
3,610
You'll get my bill for this OP, but I nonetheless feel your pain. I just don't care. Hehehehe [kidding, of course I do :)]
Best ------ battery ------ tester ------ evar!
It has 9 slots (or for the button batteries, depressions) for every kind of battery you can imagine. The only downside is that it's not calibrated. So if the exact voltage matters for most of your applications, ok, no charge. Or . . . I suppose you could spend an afternoon calibrating them yourself. This is how you find out whether or not you have OCD. [again, kidding]
herm0016
8,524
1,132
I have a fluke 1507 from a garage sale for about 100 bucks with 2 sets of new leads. HA! new price is over 600.
no more junk.
amprobe is good, they bought wavtek / meterman and have some cheaper options.
what you really need is a Simpson if you want the most accurate, reliable meter. I have been on the hunt for one for a bit at auctions/sales.
other good small stuff:
triplett 310
simpson 160
You can see that cheap and accurate are miles apart, and the 7 dollar one is 7 dollars for a reason.
Muse
41,374
10,490
Calibration? No problemo. You should see the things I've done, data data data. In fact I calibrated all my digital and some analog thermometers on Thanksgiving along with leveling my newly fixed (by me) refrigerator. They do kind of go hand in hand.
Thanks for the tester idea. I bought a cheapie tester off Amazon over a year ago but I decided it's just about useless. Is there anything wrong with using a multimeter and testing DC voltage with it? I figure it's a proxy for battery charge, but have never looked into it.
Reactions: Charmonium
Charmonium
10,654
3,610
I've always assumed a multimeter is best and it's measuring wattage that requires a load - at least I think that's how it works. I just hate having to juggle the battery and two leads to get a solid reading.
There once was a man from Nantucket
who had 3 hands . . .
It's a work in progress.
35,633
I have this one. Seems to work fine.
I gave my Fluke to my tech as he needed it more. I liked the Fluke better but it costed a lot more.
Ajay
16,094
8,116
I have a Klein as well. Seems to work well. Only annoyed it didn't come with alligator clips as well.
Torn Mind
12,086
2,774
Harbor Freight's measuring circuitry for resistance fails to hold up with the likes of crankshaft position sensors. Kleins are a good multimeter for the non-professional DIYer.
I believe the most bang for your buck Klein would be one that has clips to let you measure amperage. But they will not be as tiny as Harbor's multimeter.
Reactions: Muse
Stiff Clamp
955
360
I have a decent Triplett 1101-B:
https://www.amazon.com/gp/product/B003YHCFTU/
Haven't tested it for accuracy though.
Reactions: Muse
Leeea
3,799
5,567
I have a small fluke, and it is crap.
No idea who to recommend.
The best small unit I have is an old radio shack from over 20 years ago. I would not touch those now either.
Muse
41,374
10,490
no more junk.
triplett 310
simpson 160
I have a very old analog multimeter that I bought at Sears IIRC that I stopped using, but it sits in a drawer in my workroom. I must have bought it around 40 years ago, possibly in the late 1970's. Maybe I should use it more. It's pretty big, I have it in a box: Micronta 22-204C from Sears.jpg
Here's my Fluke 15B+ auto-ranger. My impression was that it was a fantastic deal, but I don't know for sure. Model is 15B+. I recall something to do with foreign market being the reason I got it so cheap: ~$83 including tax, 4 years ago online via TMart.com.Fluke 15B+ Autoranger.jpg
About 25 years ago my GF was freaking out because she lived next door to a power station and was concerned about EMF's. I did some research and bought a sensor plus multimeter, I trusted the guy who sold it to me, he seemed 100 legit. The meter is a Metex M-3800. You can see where it's developed a splotch anomaly in the LCD display, but AFAIK it works fine. I've only been using it to get EMF radiation readings (on occasion) but I imagine it's a decent functional multimeter:
Then there are the ~ 1/2 dozen Harbor Freight cheapies, which are convenient because I have one everywhere and they're small. But I don't trust them sometimes especially for voltage readings:
Reactions: herm0016
shortylickens
80,287
17,082
OK so, somebody in this thread posted a link or links that are fucking up the forum.
Anyway, I have some mid range Extechs that are good for home use. Just make sure you get the kind with common batteries. My mini Extech uses N cells and they are a pain to find. Get one that uses AA or AAA's.
Charmonium
10,654
3,610
Wasn't Micronta a Radio Shack brand?
I have this vague recollection that analog mms, especially cheap ones, were ridiculously easy to fry. I had something similar but very low-end.
Muse
41,374
10,490
Yeah, I probably got it at Radio Shack. I don't remember how to use this. I have the manual, it's in the picture. Strikes me as complicated compared to a digital, especially an auto-ranger.
That Fluke 15B+ has pretty good reviews at Amazon, and some very good and quite positive YT videos, for example this:
It was made for the Chinese market, which is why it's selling cheap here. Also there are questions about warranty, if there even is one if sold to US customers. However, users report well on it's stature as a solidly made device. It isn't super high end, but seems to have that Fluke quality people like in anticipation of it lasting. I did get a real good deal on it. I don't know that I have the manual. Reviewers are saying they got a Chinese manual. They say that there is an English manual, but nobody posted where to get it. Edit: Actually, it's easily found at Fluke's website.
35,633
I have a very old analog multimeter that I bought at Sears IIRC that I stopped using, but it sits in a drawer in my workroom. I must have bought it around 40 years ago, possibly in the late 1970's. Maybe I should use it more. It's pretty big, I have it in a box: View attachment 54020
Here's my Fluke 15B+ auto-ranger. My impression was that it was a fantastic deal, but I don't know for sure. Model is 15B+. I recall something to do with foreign market being the reason I got it so cheap: ~$83 including tax, 4 years ago online via TMart.com.View attachment 54021
I had a Metex for a short while before it died. I don't recall the specific model but yours looks very familiar. It wasn't sturdy enough for field use.
Reactions: Muse
14,092
The finger can also act as a very basic volt meter. Slight tingle is probably between 50-100 volts. A jolt is going to be 120v, a very big jolt is going to be 240v. If you randomly wake up and don't quite remember what just happened, it's probably 480 or 600 volts.
Reactions: lxskllr
Muse
41,374
10,490
I think I might like that. Not too big, bigger than the Harbor Freight. Comes with alligator clips too. Probably order one, see how I like it.
I set up order of Klein MM400 at zoro.com today but didn't click the place order button. But I see an email thanking me for placing the order, and I'm WTF! I emailed them. I set it up to see what the charges would be.
Edit: Zoro cancelled the mistaken Klein purchase. Big issues that day, the Amazon etc. network meltdown... ¯\_('_')_/¯
sdifox
101,236
18,234
It weighs over 16 ounces, it's my biggest.
Put it in a backpack when you need to take it out to the car. Take batteries to the multimeter. Problem solved.
Or just use those small cheap ones from HF, not like you are doing electronic work.
All decent small multimeters weight in that 16oz range. Klein MM400 is about 8 oz so if you are too weak to carry 16oz go with that.
Muse
41,374
10,490
It isn't the weight so much as the size. I'm not weak and your foolish innuendo is not appreciated. I quoted the weight because that's what I remembered, I had the dimensions written down but didn't bother finding them, but here they are:
Fluke 15B+
16.14oz
7.15" x 3.625" x 1.625"
Cen-Tech
4.11oz
5" x 2 11/16"
Triplett 1101-B
6oz
5.7" x 2.7"x1.2"
sdifox
101,236
18,234
Fluke 15B+
16.14oz
Cen-Tech
4.11oz
5" x 2 11/16"
Triplett 1101-B
6oz
5.7" x 2.7"x1.2"
like I said, just keep a small one in the car. not like you need more than 2 digit precision for cars anyway.
Reactions: Muse
