Decent low cost upgrade from 6800GT on a Pent. 3.2
alkemyst
83,769
19
My dad's video card is dying, he runs 1280x1024...likes Far Cry type games. He has a Pentium 3.2GHz (Prescott 540).
He has my old 6800GT right now. this is the list I was looking at for him from 'best' to worst. All should absolutely smoke the 6800GT...I just don't know how much power he really needs. He doesn't want to spend a lot.
5770 1GB $139.99 after $20 rebate (free shipping)
http://www.newegg.com/Product/Produc...-363-_-Product
4850 1GB $109.99 ($1.99 shipping)
http://www.newegg.com/Product/Produc...-482-_-Product
9800GTX+ 512MB 104.99 after $30 rebate ($1.99 shipping)
http://www.newegg.com/Product/Produc...-339-_-Product
9800GT 512MB $74.99 after 25 rebate ($6.98 shipping)
http://www.newegg.com/Product/Produc...-288-_-Product
let me know.
Å
happy medium
14,387
480
If it's a Agp card. look for a 7800gs.
If it's a pci-e card a 7900gt is about as fast as your cpu can push. You can get one of these used for 30$
The cards you listed are better for dual core cpu's.
You have a slower single core pent 4.
alkemyst
83,769
19
Ahh it's PCI-E x16. He may upgrade his motherboard/cpu later this year though...
If anyone knows a route with onboard video that would be better and support 1280x1024 gaming he'd be interested in that. He needs to replace his hard drive at the same time as it's about 5.5 years old now.
happy medium
14,387
480
Any on board video at this time is slower then a 6800gt.
I would not go that route.
Don't forget with today's cards you need a decent power supply.
What he got under the hood? :)
edit: He needs a whole system upgrade ,a new video card will do nothing for him ,sorry. :(
SlowSpyder
17,305
1,002
Are the Pentium 540's socket 775? Maybe look at a cheap C2D upgrade if it is.
If you're keeping that CPU I really doubt it'd be worth going past Radeon 4670 level performance. To tell you the truth that might even be a bit GPU heavy for that CPU. But, they are cheap, are a solid upgrade over a GeForce 6800, and are pretty power efficient.
http://www.newegg.com/Product/Produc...on%20HD%204670
alkemyst
83,769
19
His motherboard is a 925XE chipset (ASUS P5AD2-E Premium) think it only supports single cores.
happy medium
14,387
480
Yea it's possible your motherboard supports core 2 cpu's. Highly unlikley but possible.
Good catch Slowspider.
toyota
12,957
OP none of those gpus you listed would be appropriate. none of those cards would even be utilized enough to be worth the cost. if you are sticking with that cpu then Im with SlowSpyder on this one. there is zero point in getting anything faster than a 4670 and even that would not come close to being fully pushed with that single core P4.
happy medium
14,387
480
Well that sucks...it does only support single core cpu's.
A video card will not give your system a boost, your cpu is too slow. :(
I had the same speed cpu and it bottlenecked my 7800gs which is 15% faster then a 6800gt.
It's just not worth it.
alkemyst
83,769
19
he will be upgrading his system though (motherboard/cpu/memory) later this year. Since his card is dead he has to pick up something. He'd rather get something that will run on the next machine. He doesn't plan on going much beyond 1280x1024....he's in his 60's.
Dark Shroud
1,576
I would recommend a Core i3 then, you can give it a nice little OC if you want and pair it with a 5770.
toyota
12,957
by the time he decides to actually upgrade that pc there will be better video cards for the same prices as those you listed. unless he has concrete plans to upgrade soon then theres no point in buying anything more than a $50-$60 card.
0roo0roo
64,795
84
his cpu is so obsolete that it probably would choke on portal. anything he buys now will be choked to death by the cpu, at this point you are far beyond such an upgrade making sense, wait till you can get the cpu along with the gpu, otherwise its just tossing money down the drain
alkemyst
83,769
19
He was going to upgrade in a couple months. He is taking a couple classes now and it preoccupied with that. Now that his video card died he needs to buy something.
alkemyst
83,769
19
I was thinking if we went with this:
GIGABYTE GA-MA78LM-S2H $49.99 +2.99 ship ($10 rebate)
AMD Athlon II X2 255 $67.99 free ship
Ram 4gb 95.99 free ship
4850 109.99 1.99 or the 5770 for $30 more
Caviar Blue 1TB $69.99
under $400...don't know if their is a better bang for buck motherboard/cpu/ram combo...
He's not a hardcore gamer and at 1280x1024 (and 1680x1024 if he upgrades that one day) is not much pixel pushing.
Don't know if this is all in his budget right now. He needs at least the drive and video card so he's halfway there.
Paratus
17,718
16,006
I recently had a 3.2 P4 and AGP X1950 PRO 512 and it could play most games at 12x10 and medium to high settings. Crysis ran mid 20s at medium settings @10x7. I played L4D, Oblivion, Crysis, Warhead, ME1 and had fun doing it.
alkemyst
83,769
19
He is going to upgrade to the build above, he's going to go tri-core (x3 440) and maybe the 5770 vs the 4850. I just don't know if that's overkill at even 1680x1024.
I don't think quad will be worthwhile for him. i am also debating picking up USB 3.0 and SATA 6.0 for $40 more...USB 3.0 I can see taking off. SATA 6.0 only for solid state stuff.
