Decent gig-ethernet SOHO router w/port level IP ACL capabilities
RhythmAddict112
Hi All,
I've been running some cisco gear (2501 switch, 2600 series router) for a LONG time. It all works great, but I am tired of needing to mess with configurations and really just need an upgrade.
I need a good recommendation on a SOHO router. I must have something that'll let me do port-level permissions on IP/IP-ranges. For example, I need to open up port 3389 from my place of work so I can remote into my machine from work. I would also really love to have gigabit ethernet on the switch.
What do you guys suggest?
Thanks in advance!
Forgot to mention: Would be great if it has wireless (G/N) but not a requirement if it's not do-able.
That's correct, I need port forwarding with the ability to say only a certain inbound IP can hit that port. Ex: only 1.1.1.1 has access to port 3389. I don't want to just open a port to the world. Do most routers these days provide that functionality?
Thanks
Thanks, that does look like it'll do the trick. If anyone else has suggestions on specific routers that'll accomplish the same thing, that would be fantastic.
