OK.....I'm lost.
I'm on the woody build of Debian.....and have used *nix for a while, but this is my first go round @ Debian.
I've sucessfully been able to get Slack, Suse, and Redhat on this box w/ X running no problems. In Slack I just used xf86config to get it up.....and RH and Suse were automated.
The problem I'm running into is b/c of my chipset----intel 810 integrated agp slot.
Which, when I do a google search, most references point to older kernels needing a kernel refresh of agpgart...and the kernel referenced is 2.1 or 2.2.
I've tried two different ways of getting X up and running----one with the standard install wizard, and two with xf86config. When I run xf86config I can choose the i810 chipset----
Here's two links for you:
1 MY XF86Config4 File
2 MY X Error Log
I'm no wizard with X-----and I don't know where to go from here. I've been to a bunch of diff't web pages and the only possible advice I found was that for the i810 the device wasn't properly created, and the command "mknod agpgart c 10 175" needed to be run under root in the /etc directory......
2 MY X Error Log
